Paul Posted November 8, 2015 Report Posted November 8, 2015 My next job for the new patrol is installing x2 reversing lights ( camping lights) in the rear running threw a relay and switch in cab. The patrol has a few blank switch caps installed in the front were I can mount a switch, is there a switch which fits these holes ? I would like to put a rocket switch in with led light in it but cant find one that will fit. Do you just have to cut more out or can you get adaptors? Cheers paul
Rumcajs Posted November 8, 2015 Report Posted November 8, 2015 I have a switch from Jaycar which just fits in to original slot ==> SPDT ON-OFF-ON rocker switch cut out size 34x21 mm, measure the slots then find switches to fit. Cheers
