skid Posted August 1, 2015 Report Share Posted August 1, 2015 GU converting auto hubs to manualWill the manual hubs from my old GQ fit as a replacement to the auto hubs on a series 2 GU?Thanks in advance Link to comment Share on other sites More sharing options...
ricster Posted August 3, 2015 Report Share Posted August 3, 2015 As far as I know yes they will fit. The only real difference between the GQ and GU on the front suspension was the wheel bearing lock nut... other than that I think they are identical.Why would they change something that works well.... hmmmm.... ok, don't answer that Link to comment Share on other sites More sharing options...
Rumcajs Posted August 8, 2015 Report Share Posted August 8, 2015 Yes, they will fit but don't forget to obtain "egg spacer rings" as well and make sure the shaft end float is within certain tolerances between the shaft's circlip. You will need shorter bolts too.CheersConverting auto hubs to manual takes 10 mins, vice and large screwdriver to pry out the auto clutch. Good as any manual hubs conversion.Regards Link to comment Share on other sites More sharing options...
