skid Posted September 10, 2014 Report Posted September 10, 2014 Does a 98 series 1 GU have a transponder built into the key?
Rumcajs Posted September 10, 2014 Report Posted September 10, 2014 (edited) It depends if you have NATS (Nissan Anti-Theft System). Since you are not referring to which vehicle exactly (type/trim/engine model e.g.) If your have a red blinking indicator on top of the dash near windscreen when ignition is off than yes the key has the immobilizer transponder/chip in it. See pic bellow Edited September 10, 2014 by Rumcajs
beast98 Posted October 2, 2014 Report Posted October 2, 2014 i have a gu 98 2.8 td st and it has a blinking light on the dash, there is also a nats sticker in the glove box, and your key should have a red plastic tag on it, if you have none of these you dont have nats,
