Kranwa Posted July 26, 2014 Report Posted July 26, 2014 Hi guys. Got a strange one here. Have owned the truck just over 3 months and slowly overt the last month or a little more it had been getting really difficult to get into 1st 2nd and reverse. At first I thought it was maybe syncros but it was 3 of the gears all around the same time. Also I found a receipt in the glove box for a full gearbox rebuild and clutch replacement 2 years ago less than 30,000ks ago. I've bleed the clutch a few times now and while the clutch feels a lot better the problem has not improved. It feels like the pressure plate maybe cos when I stop and leave it in gear I can feel the truck want to crawl forward like the clutch hasn't fully disengaged. It looks as though I've got full movement from the slave cylinder but I never really checked it out before I had the problem. Surely the clutch isn't stuffed so soon after being replaced.
Rumcajs Posted July 26, 2014 Report Posted July 26, 2014 So where on the pedal position do you feel full clutch engagement. Is it early at low position? You need to check if the lever linkage isn't binding and also make sure the bell housing isn't full of mud/crud which doesn't help. Normaly you'll get the clutch slipping as it wears out and take up point moves up on the pedal travel. This sound like something is inhibiting full clutch travel or it could be that you aren't getting the full clutch travel due to hydraulic failure. Cheers
Kranwa Posted December 17, 2014 Author Report Posted December 17, 2014 (edited) It was the master cylinder for the clutch. All good now Edited December 17, 2014 by Kranwa
BigGQWesty Posted December 27, 2014 Report Posted December 27, 2014 Be prepared for the slave to go soon. Karma usually plays like that
