Shorty1989 Posted December 18, 2013 Report Posted December 18, 2013 Lately my car has been very hard to get into any of the gears and most of the time I can never get it into reverse without it just grinding. What could this be? And also On my way to work today I stopped at a set if traffic lights and left it in 1st gear with the clutch in and it kept wanting to go forward until it stalled. I then started it when the light went green with the clutch in and in 1st gear and it was like there my clutch wasn't even in. What could it be?
Rumcajs Posted December 19, 2013 Report Posted December 19, 2013 Looks like your clutch is not disengaging fully. Possible causes could be lever, hydraulic cylinders (master/slave) or combination of both. Cheers
BigGQWesty Posted January 1, 2014 Report Posted January 1, 2014 Check your oil levels first. You may have a leaking master cylinder. If oil levels are good you may need to adjust the slave cylinder throw to take up the slop of wear in the clutchKallen WestbrookOwner ofWesty's Accessories
