rmb3218 Posted May 1, 2012 Report Posted May 1, 2012 Hi All, I have a GU ute with rear coil springs. I already have a 50mm OME lift with 250kg springs which have done approx 90K and are starting to sag. I have fitted a rear coil support. I am considering coil-rite air bags or replacing the rear springs with 400kg springs. I would be interested in hearing from anyone who has fitted either. Kevin
Bizz Posted May 1, 2012 Report Posted May 1, 2012 I've put coil rite bags in my gq which has 350ks on it and I reckon the rear springs are the originals
rmb3218 Posted June 7, 2012 Author Report Posted June 7, 2012 I have just fitted coil-rites with Kevlar bags. What pressure does everyone run loaded and unloaded
Bizz Posted June 8, 2012 Report Posted June 8, 2012 Ive fitted coil rites to my gq and I'm slack and leave it on about 15psi empty (a bit rough) or full.
Keanie Posted October 3, 2013 Report Posted October 3, 2013 My 04 GU ute has arb 400kg rear springs, coil rite bags. Just done 9000k trip in rough country with slide on. Fully loaded with water, fuel etc was around 3.9t, know this because put over weigh bridges. Had GVM upgraded. Handled great. Re the bags I ran 20psi in them all the time, even empty, blew a bag on the Hay river, was caused by a stone getting between the Kevlar cover and the bag, the single bag handled it till I got to Alice and could get another one. Found out not to use the cover on bags as we don't use over 35psi.
