Davepatrol Posted May 23, 2012 Report Posted May 23, 2012 Any one looking for Leds for your rear doors check out this bloke. http://www.ebay.com.au/itm/270961586205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 This is how mine turned out. Very happy with the lights Makes it easy to see in the fridge. jamus 1
Ray! Posted May 23, 2012 Report Posted May 23, 2012 I bought something similar to do the same, but after finding out that there's not on single power wire in the rear door, I couldn't be fagged pulling one through the rubber harness cover. Cheers Ray
BigGQWesty Posted May 23, 2012 Report Posted May 23, 2012 (edited) Being into RC stuff this is what the father in-law and I have and will be using.. http://www.hobbyking.com/hobbyking/store/__14290__High_Density_Waterproof_LED_Flexible_Strip_White_1mtr_.html Edited May 23, 2012 by BigGQWesty jamus 1
Davepatrol Posted May 23, 2012 Author Report Posted May 23, 2012 I bought something similar to do the same, but after finding out that there's not on single power wire in the rear door, I couldn't be fagged pulling one through the rubber harness cover. Cheers Ray The kit suppies al the wiring to pick up power from the rear interior light, He supplies a step by step instruction sheet and every thing you need to do the job. Cheers Dave
Ray! Posted May 23, 2012 Report Posted May 23, 2012 I have power available in the rear panels, but now that the table is solidly mounted, I can't be bothered to drag wires through. I just hang an LED light on the door. Cheers Ray
Big gu Posted May 27, 2012 Report Posted May 27, 2012 I have seen these but why not run a long strand along the sides and top of. The rear cargo area ,then you don't have to pull wires through to put power onto it I'll take some pics when I finally get mine sorted out with draws etc have bigger problems at this time
