Arch Nemisis Posted May 22, 2012 Report Posted May 22, 2012 Can some tell me if it's possible to remove the sump with the engine still in place. Will I need to jack the front up and drop the shocks, sway bar etc? Thanks in advance.
Arch Nemisis Posted May 22, 2012 Author Report Posted May 22, 2012 Oops TD42 silvertop Do Nissan make any others? ;-)
Ray! Posted May 22, 2012 Report Posted May 22, 2012 Oh, you're after info on historical engines. I can say with authority that you can remove the sump, in situ, on another ancient engine, the SD33, so the same could be for that old timer. Cheers Ray Glort 1
cairnsGU Posted May 22, 2012 Report Posted May 22, 2012 Yes..the sump can be removed in chassis...also unlike a zd30..you can get to alot of other parts on the motor Dan
Arch Nemisis Posted May 22, 2012 Author Report Posted May 22, 2012 So no need to touch suspension then? Zd30 is that an oil filter? I'm familiar with the ryco z115 :-)
gottheshits Posted May 22, 2012 Report Posted May 22, 2012 Zd30 Its the engine for today.......... Throw away tomorrow. BigGQWesty and Glort 2
