admin Posted March 30, 2012 Report Posted March 30, 2012 I recently installed a Projecta dual battery monitor and I must say that Im very impressed with it. The display is fantastic and it really gives you a good idea on your battery health. The whitish smear over the face of the unit is from when I used metho to clean the dash prior to puttin on the double sided tape to hold the unit in place.. I got it everywhere. video here My starter battery is a little on the sad side - as you can see from the video and images. I have a redarc 1220 which charges the second battery for me - Extremly good unit.
cairnsGU Posted March 31, 2012 Report Posted March 31, 2012 Isn't that a low voltage output if car is running ?
admin Posted March 31, 2012 Author Report Posted March 31, 2012 Yeah, this is what I thought also. I wasnt sure if the dud battery was bringing it down or if the alternator was a bit dud to. Does anyone know what the idle voltage should be?
cairnsGU Posted April 2, 2012 Report Posted April 2, 2012 You should recieve 13 - 13.8 volts by memory with engine running Try charging it and the loading up, Good way to check battery is via the following: 1. Completely charge battery 2. put suspect battery inlace of your normal starter battery 3.check battery voltage while ignition off, should be around 13 volt 4.turn ignition on and check voltage 5. start car whilst watching voltage and if it drops under 12 volt its rooted.
cairnsGU Posted April 2, 2012 Report Posted April 2, 2012 After my engine going bang last week and the expense that i have incurred over it... I am to scared to spend any more moony on it lol
admin Posted April 3, 2012 Author Report Posted April 3, 2012 Went to battery world to get a new starter battery today but before try sold it to me they did a test on my car and the result was 'excessive ripple' - from the alternator rectifier. So I've got the car booked in for tomorrow for either a new rectifier or whole new alternator.
GeoffM Posted April 6, 2012 Report Posted April 6, 2012 I thought the best charge voltage was about 14.2 vdc. Most CRD diesels seem to charge at 13.8 vdc.
admin Posted April 6, 2012 Author Report Posted April 6, 2012 New alternator fitted - things are much better now. Old alternator had stuffed rectifier and the clutch was not right on it either.
cairnsGU Posted April 9, 2012 Report Posted April 9, 2012 Thats good..I don't have a clutch on my alternator.
admin Posted April 9, 2012 Author Report Posted April 9, 2012 I went away this weekend and the new alternator is certainly performing way better than the old.. I was on the road for about 2.5 hours and my D250S Dual ctek in the camper trailer put over 50ah into my battery bank in the camper trailer.. Very happy.
dronus4x4 Posted May 9, 2012 Report Posted May 9, 2012 That looks very neat. Could i ask where you bought it from, it looks like exactly what i have been looking for. I was going to get a couple of voltmeters on ebay and make something up but that looks a lot neater..
admin Posted May 9, 2012 Author Report Posted May 9, 2012 Your can get them on eBay or several online stores. I got from a camping show at one of the stores there.
dronus4x4 Posted May 9, 2012 Report Posted May 9, 2012 Your can get them on eBay or several online stores. I got from a camping show at one of the stores there. Cool thanks. I found one on eBay but will start keeping an eye out for them. I showed the missus but she just rolled her eyes and went back to the TV.. if she won't get excited about that I'm not sure how she is going to react to the recovery points and kit I'm eyeing off KMsMK 1
admin Posted May 9, 2012 Author Report Posted May 9, 2012 The projecta has a beautiful little display - :-) Im a sucker for a bit of a nice display. You wont be dissapointed.. It even connects to your headlight signal (which you can get from the back of the radio) and it will dim the display at night so it doesnt blind you.
Jacket_1985 Posted May 11, 2012 Report Posted May 11, 2012 That looks a lot better than my last system. . . i like the dimmer function too. . . mine didnt have that.
KMsMK Posted May 11, 2012 Report Posted May 11, 2012 I was looking at these online today and thinking I might get one, you've now convinced me. Sent from my iPhone using Tapatalk
