EGT Survey ZD30 DI/CRD
geeyoutoo
OK, just in case, I would like to get my EGT survey thread up and running here as I think there was a lot of good quality info in the other one for new and old members alike. I looked at bringing the info across but I only own my info so it may not be legal and there would be a hell of a lot of sorting to get it right.
If you are interested in keeping this going please use the structure below in a cut and paste form and add your info over mine.
There always seems to be a question of where and what EGT temps are acceptable with the GU ZD30 motor and with EGT being so critcal to the longevity of the motor you can never have too much information.
The position of the EGT sender, ie pre or post turbo, the distance from the turbo dump pipe flange, the temp range you experience, cruising, towing, city, give others valuable info. Also add whether DI or CRD and what brand gauge is used. There are other aspects which may effect EGT which I have added as well. Fuel eco, well thats just so you can brag or squirm.
Here goes, it will be a WIP.
2000, DI manual, 21700 k, Update #4
---------------------original info-----------------------------update info
Dawes --------------No-----------------------------------------Yes
Needle V------------No-----------------------------------------Yes
EGR done----------Yes----------------------------------------Yes
Snorkel (Safari)---Yes----------------------------------------Yes
EGT Boost---------Autometer Analogue------------------Unchanged
EGT Sensor-------60mm from dump pipe flange-------Unchanged
Cruise temp-------@100k, 10-12psi, 240-450C---------7-12psi, 210-320C
Cruise temp-------@110k, 4-6psi, 350-550C------------10-18psi, 230-430C
Tow Temp---------@100k, 10-12psi, 400-550C---------12-18psi, 320-460C
City temp-----------150-350C, 5-8psi-----------------------150-250C, 5-8psi
Tyre size------------265/75/16 @ 40psi---------------------Unchanged
Chip------------------Safari DTronic----------------------------Unchanged
Exhaust-------------Standard-----------------------------------Beaudesert 2 ¾"HF Cat
Intercooler----------Standard----------------------------------Cross Country
Lift Pump------------No-------------------------------------------Carter 4600HP
Fuel Eco L/100----Best 8.8----------worst 17.5------------Average 11
Edited by geeyoutoo
2004 GUIV, DI manual, 210000 k, U
Cruise temp-------@100k, 7-11psi, 280-470C
Cruise temp-------@110k, 8-12psi, 350-520C
Tow Temp---------@100k, 10-12psi, 380-600C 1700kg
City temp-----------200-400C, 5-10psi
Tyre size------------will double check
Chip------------------nul
Exhaust-------------Beaudesert 2 ¾"HF Cat
Intercooler----------Standard rewelded
Fuel Eco L/100----Best 12----------worst 17.5 average 14
Edited by gottheshits
2003 GU3, DI manual, 285000 k,
Dawes --------------yes
Needle V------------yes
Snorkel ---Yes
EGT Boost---------
EGT Sensor-------50mm from dump pipe flange
Cruise temp-------@100k, 7-11psi, 280-400C
Cruise temp-------@110k, 8-12psi, 350-430C
Tow Temp---------Don't know, don't tow
City temp-----------200-350C, 5-10psi
Chip------------------nul, none zip, zilch, bugger all.........SO FAR
Exhaust------------3 inch hi flow cat into stock pipe and sports muffler (str8 thru)
Intercooler----------ARE
Lift Pump------------Carter
Fuel Eco L/100----Best 10.5----------worst 13.5 average 12ish
Edited by Bogmeister
