cairnsGU Posted May 8, 2012 Report Posted May 8, 2012 Hey guys. Anybody used this oil in a zd30 ? This is what the engine rebuilder used in the motor. If so do you know where to buy and how much. Specification ACEA A3 / B3 / B4 API CG-4 / CF / SL Approval DEUTZ DQC I-02 MAN 271 MB-APPROVAL 228.1 MB-APPROVAL 229.1 MTU DDC TYPE-2 FUCHS Recommendations ACEA E2 MIL-L-2104 E ALLISON C-4 CASE MS 1120 DAF MACK EO-L NH 330 G SCANIA STEYR A-202 VOLVO VDS VW 501 01/505 00 • High performance lubricant for diesel & petrol engines, with and without turbochargers. • Equally suited for highway & construction vehicles • Designed to meet the requirements of European equipment, • High detergency level ensures maximised engine cleanliness and minimal bore polishing or ring sticking • Excellent viscometrics produce a stay-in-grade and maintains quality even in the most severe conditions. • Protects against sludging. • Compatible with all gaskets and seals. • Good corrosion protection. • Miscible with all mineral oil and synthetic based engine oils therefore no flushing required. http://www.fuchs.com.au/categories.asp?cID=10&c=81331 Dan
dronus4x4 Posted May 9, 2012 Report Posted May 9, 2012 Sorry, never used it. Ive tried a few oils (Magnatec, Penrite and Delo400) and have allways gone back to the Dello. Patrol seems to like it, so so do I!
Bogmeister Posted May 10, 2012 Report Posted May 10, 2012 I am using their concentrated coolant, it seems to be good.
