Stephen Posted November 26, 2019 Report Posted November 26, 2019 I have no engine light no globe Light motor turns over does not start not getting fuel to injectors have primed fuel system fuel coming out of return line I am thinking fuel pump not getting signal what has this got to do with no engine light at all so I can’t get any codes up has anybody got any ideas 🙏
Rumcajs Posted November 29, 2019 Report Posted November 29, 2019 (edited) G'day, Firstly, you'll ned to tell us what model/year your vehicle is! if ZD30 then yes no MIL light likely means that engine ECU is not powering up. There are fusible links in the engine bay right next of main battery. Cheers Edited November 29, 2019 by Rumcajs
Stephen Posted November 29, 2019 Author Report Posted November 29, 2019 My Nissan is a D 22 2002 Diesel turbo Have been googling the problem just wondering Can you tell me which terminals to use so I can hotwire my injector pump to see if it works
Yendor Posted December 6, 2024 Report Posted December 6, 2024 More than likely a blown engine control fuse
