I've got Walbro FRB-13, good unit but I think I can make it even better with Walbro FRB-22 (higher output pressure) so I'll be changing soon to that one.
Other use Carter 4600 if I had space under bonnet (my preferred instalation location) I'd get FASS unit with built in fuel filters. With Carter you have make a by-pass installation if it stops running, with Walbro you don't its flow trough is unaffected if the pump is off.
