Hillbilly92
Hillbilly92's Achievements
  1. Hi guys n gal's Hillbilly is my name n I'm new to the game Recently purchased a 92 efi tb42 gq The other day I washed her after taking her out for her weekly bushwalk now I may have ****ed up by pressure washing the engine bay as my issue has only started since doin so... (Note I did have the engine running whilst doin so) The issue I'm having is first start up starts fine let her run for a few minutes( or go for short drive) then turn it off let it sit for a min or two n try start it again n it won't start unless I've removed fuel pump fuse then start it n let it run for a sec or 2 then put pump fuse back inπŸ€” every now n then it'll start back up ok n then it'll start up rough as guts and lumpy black smoke chokey acceleration...πŸ€”πŸ€¦πŸ»β€β™‚οΈπŸ€·πŸ»β€β™‚οΈ I have no idea I've replaced fuel filter ,fuses, cleaned the map, cleaned the air filter checked wiring everything I've checked seems to be in working order...πŸ€”πŸ€¦πŸ»β€β™‚οΈ On another note I also have a clunking noise coming from front end suspension when turning sharply or goin over bumps πŸ€” my thoughts are tie rod n drag link possibly need replacing as I've put in a 2inch lift recently also πŸ€” Any info on these to problems would b muchly appreciated Thankyou all in advance ☺ πŸ’―
