Well, the problem turned out to be the pump and I dropped the van off at a recommended reliable diesel mechanic (remember, small island in the West Indies!!). He said it's a common issue with this vehicle and others that carry the same pump and the major culprit is poor quality fuel (I was told by a friend working in the island's petroleum distribution company that we do not receive or refine "Diesel" as such. He says we are supplied with GAS OIL, not white diesel). The mechanic had at least 3 Mitsubishi L300 vans, along with Nissan Frontiers and a couple more Caravans so it's not me alone with this suffering. I did some checking on the forum about the Carter 4600 pump and I think that I understand fully what it actually does, providing an ample supply of pressurized fuel to the diesel pump so that the diesel pump itself is not under strain to pull fuel all the way from the tank so I'll look into that. Problem is, with the tight spaces, will I find room to install this lift pump inside the tight confines of this panel van? Other questions...(Please be gentle. I have 0 knowledge of the build of this engine) 1/. Is this lift pump installed after the fuel filter? I would assume "YES" to avoid additional strain on the diesel pump to pull fuel through the filter. 2/. What is the purpose of the spill/injector leak pipe? Does this allow excess fuel sent to the injectors to flow back to the tank?
