Wow and thank you very much , my problem is intermittent, and being a newbe I am not exactly sure what the designation is for this model hence does it actually have a second switch. 2004 patrol 3 litre diesel. I had a look at the exhaust side and couldnt find another switch? Any help with the location? I ASSume its on the other side (exhaust )? Many thanks and I dont think the resistor is bad as it is intermitant?
I have since read on here this is a common fault, there are two switches on either side of the engine.
Are the switches the same and I dont see any reason to replace the resistor if the switch is staying grounded.
Thanks
Hello, newbe here with a question.
I have a 2004 Patrol 3.0 ish diesel with oil pressure light on when starting cold and wont go out unless you turn off and on several times?
Switch sticking, is that a common fault?
And part number if possible,
May thanks for your observations
