Shorty1989
Members-
41 -
Everything posted by Shorty1989
Lately my car has been very hard to get into any of the gears and most of the time I can never get it into reverse without it just grinding. What could this be? And also On my way to work today I stopped at a set if traffic lights and left it in 1st gear with the clutch in and it kept wanting to go forward until it stalled. I then started it when the light went green with the clutch in and in 1st gear and it was like there my clutch wasn't even in. What could it be?
lift kit information
Shorty1989 replied to Shorty1989's topic in Nissan Patrol GQ/Y60 & Ford Maverick (GQ Patrol, 1988–1997)
Thanks, will check it all out on weekend. Will it cause damage? -
So I did the 4" lift on my car. I did 4" shocks and springs, adjustable panhards, caster correction plates, extended brake lines, and extended sway bars. Then I took it for a drive and theres now a small vibration and a loud grinding type of sound. Then I put 12mm transmission spaces and a double carden shaft in the rear to try and fix the problem. The problem is still there! the loud grinding noise could be something vibrating very fast but I just don't know. I thought a thrust bearing but it wasn't doing it before. What else can I do? -
Thanks for your reply. Great help -
Thanks for your help, what about raw 4x4? -
I'm currently looking at purchasing a 3" lift kit this week but there are so many brands out there. Just wondering what brands are the better ones to look into. I've been looking at raw 4x4, ironman, dobinson, and a weird unheard brand called anarchy offroad. Tough dog is just a little out of my price range. Any opinions would be great.
engine over revving
It was stuck in max position but all fixed now. Thanks for your help -
engine over revving
Thanks, will have a look tomorrow -
engine over revving
Max revs on its own? -
My gq tb42 motor is over revving. What happened is I just started my car up in the cold and drove it easy up the road then I put the accelerator further down and it started coughing and splattering obviously cause the automatic choke was still on. Strait after that it just revved out and I've checked the throttle which doesn't seem to be stuck. Any ideas would be greatly appreciated?
Diff ratio
Thanks mate -
Diff ratio
Is there Spose to be a crush spacer on the drive pinion? -
Diff ratio
Ok, so It's a brand new 3:9 ratio and I need a 4:1 Great -
Diff ratio
Thanks, will do it tomorrow -
I bought a diff centre today but unsure of the ratio! Is there a way to tell the ratio or will it have to go to a diff place to get checked?
