  1. Maybe get some zips installed down either side of the front flap. So you can fix it down during the night. Kallen Westbrook Owner of Westy's Accessories
  2. Can't 100% remember, Fold your 1/4 edges under to make a flat surface, and yea I think it was rivets. Lots of sicafkex to Kallen Westbrook Owner of Westy's Accessories
  3. Welcome back Alan. Have just sent you a pm Kallen Westbrook Owner of Westy's Accessories
  4. There are a few no weld jobs aswell.. the hardest part is making the fill in pannels, but template it and you should be good Kallen Westbrook Owner of Westy's Accessories
  5. Hi mate. I've heard some good things with the $600 jobbies on eBay. The turbo is a basic bush setup, but you can't go wrong imo. Comes manifold, oil lines, turbo, the lot.. "]http://www.ebay.com.au/itm/Nissan-Safari-Patrol-4-2L-TD42-TD42T1-GU-GQ-Y60-Turbo-Manifold-Turbocharger-/190786035472 Kallen Westbrook Owner of http://www.nissanpatrol.com.au/forums/showthread.php?15134-Westy-s-Accessories.-A-small-back-yard-builder. Westy's Accessories]
  6. Hay mate. How did you go? Kallen Westbrook Owner of Westy's Accessories
  7. Hi guys. Long time no speak. Been quite busy of late.. Well were flat out prepping for a few first big family camping trips and the wife found this list producing site. http://www.campinglist.net/ Not a complete list for all occasions, but a dam good starting point for nubes. Kallen Westbrook Owner of Westy's Accessories
  8. Looking tough as.. 4000k from a set of rubber... That hurts.. Kallen Westbrook Owner of Westy's Accessories
  9. Welcome mate and glad to be a help. The company I got these from also do the split/ sliding options but use an alloy frame so they'll last for ever. A bit more expensive than the fixed ones but if you want to open them for access then a great option Kallen Westbrook Owner of Westy's Accessories
  10. Hi guys. Long time no speak.. or tap.. I got under mine again and re tensioned it all up and all good.. Glort it sounds like your rear panhard rod is shot.. Kallen Westbrook Owner of Westy's Accessories
  11. Well guys. We raised a total of $1200 for the month. It's not to late to throw a couple of bucks in either Kallen Westbrook Owner of Westy's Accessories
  12. Turns out they had leaking beads. I tried fixing them but no good.. $20 at the local tyre place and its all good... Kallen Westbrook Owner of Westy's Accessories
  13. Well I've just bought a 7" tablet for the road, and remembered this thread.. I also have no 2nd din point due to the stereo and UHF filling those spots, but I do have a ciggi try with no smokers to use it.. So I'm going to try mount it there using the timber block idea. Either that or make a clamp or plate mount coming from the Jesus bar. Kallen Westbrook Owner of Westy's Accessories
  14. Well bad news.. It's returned.. Very slight when going threw drains and speed bumps.. Will jump under it and check tension again and let you know.. Kallen Westbrook Owner of Westy's Accessories
  15. Ok I've made an executive decision.. Lol Every set sold threw the month of November, I will be donating $2 to team Silver Rollers for Movember.. So now you can get bling and be helping a great cause.. So snap them up guys.. You can follow us rollers here http://www.nissanpatrol.com.au/forums/showthread.php?t=15666 Kallen Westbrook Owner of Westy's Accessories
  16. Cha Ching, show us some bling.. finally arrived.. i recon the postie got lost.. pm's sent out
  17. It's crazy how much work is missed when doing simple changes hay.. And there the pros.. Kallen Westbrook Owner of Westy's Accessories
  18. There in Melbourne.. So hopefully here Tuesday. I'll send out pm's to all who are interested once in my hand with final postage prices. Kallen Westbrook Owner of Westy's Accessories
  19. Today was a productive day.. Installed some sound deadener (poly quilt filling) in the rear doors.. This enhances the bass to nearly sub quality, and eliminates the sound heard outside.. Then ran my wire to the rear for my work light, and installed a fuse box for the fridge, spotties and work light.. Nice and clean now Just a single positive wire to the fuse box, which runs a buzz bar threw the middle and the out either side.. Very neat and good for 50A continuous.. Kallen Westbrook Owner of Westy's Accessories
  20. Fixed the clunk coming from front axil, removed front sway bar.. Then went out and flexed up the new setup.. With rear engaged. And factory rear disconnected. Kallen Westbrook Owner of Westy's Accessories
  21. Well for the last year I’ve had a clunk coming from the front end of the GQ and I have got under there a couple of times but have not been able to pick the issue. The clunk only happened when the left wheel compressed. So I checked radius arms, springs, shocks, sway bar, the lot. Nothing. Well in the last few weeks it has been really bad and with the old man down I jumped underneath and got him to jump on the bull bar while I inspect it. I’m the first jump I picked the issue. The bolt holding the rear radius bush on the diff was slopping up and down. And about 2 mm's as well. Bummer. So I assume the worst, its flogged the mounting plate out. So today I start to pull the bolt out, it was loose as, so a ratchet and shifter was all I needed. Well there is a little wear in the diff mounting plate, but most of it was in the thread which had completely rounded off. TFFT is all I could say. I popped down to Blackwoods, grabbed a new M16x1.5 pitch (metric fine) by 80mm long in 8.8 grade and I was on my way home for $3... Now before I bolted it back up I checked how bad the hole was.. It was 16.5x17mm.. .5mm elongated so in my eyes pretty good. If it happens again I’ll be welding some washers to the plate either side to get a nice snug fitting hole again.. So it’s all back together again and no clunk.. I also went of the other bolts in the front end and all were tight. So wether this one was missed after the lift install and castor correction bushes fitted I’m not sure.. I will be rechecking in a couple of week’s time.. So if you have any sort of clunking noise check it out.. It could have been a lot worse for me...
  22. One week down.. Kallen Westbrook Owner of Westy's Accessories
  23. I get the same thing.. I have been told that the aftermarket castor correction bushes are slightly thinner than the Nissan ones. Mine has had the clunk ever since fitting the OME correction bushes. So I intend on greasing the lot, and trying. It only clunks when RH compresses.. Kallen Westbrook Owner of Westy's Accessories
  24. Is it your sway bar clunking on the radius arms? Kallen Westbrook Owner of Westy's Accessories
  25. Popped the hood. Ran some subi top end cleaner threw it.. Closed hood.. And noticed both rear tyres have slow leaks.. just add that to the list... Hopefully will be removing front sway bar to.. Will report on drivability after.. Kallen Westbrook Owner of Westy's Accessories
