  1. Super massive black hole.. The Muse..
  2. Spot on.. As don't go D shackles. The cant take the side loading like bow shackles can. Some great tips there..
  3. Turn back time, Tina turner.
  4. Owell.. Floors are a bit stuffed after 2 generations..
  5. What size did you use for your initial bar??
  6. Available for GQ?
  7. Don't forget the old faithful riggers gloves.. They will save many cut, Knicks and pinches while dealing with your recovery gear.. Only a few $$$ and avalible in many sizes from any good safety store..
  8. Had the time of my life - David Cook (unsure I got the artist)
  9. Hot coffees or hot showers? Were from and how does it work,,
  10. And now the law suit to follow...
  11. Being into RC stuff this is what the father in-law and I have and will be using.. http://www.hobbyking.com/hobbyking/store/__14290__High_Density_Waterproof_LED_Flexible_Strip_White_1mtr_.html
  12. Yes, as I said don't fill and shed it.. You have to drive..
  13. Dropping the tank is easy enough I have been informed if you have access to a hoist..
  14. Yeeee haaarrrr... My car finally appreciated... Lucky I didn't buy the HQ Monaro...
  15. Spent Sunday getting an extra 20ltrs in my tank.. Yep, the old breather move trick.. Got an extra 22 to be exact..
  16. Yep.. Mine is the diesel sorry.
  17. Sorry but I thought you were talking stick welders.. My bad.. But what I have said still stands.. Your power supply is vital. And a 180-200 mig is a nice little welder.. But quality is s must.. CIG, WIA, BOC... Spend it right, spend it right..
  18. Simple really. Took me 40 mins (20 to get the plug apart...)
  19. Reefmagnet Yep.. That's how they work. You weld about that make and the welder will only draw 10A.. Crank it to 150+ it pop.. Tonka I've just spent the afternoon rebuilding and hard facing a 12mm chute for a timber chipper using a 130A BOC stick welder.. Like I said, buy decent and buy it once.. Doesn't need to be extreme amperage.. Just quality.. EDIT.. Has just clicked later in the thread that were talking mig welders, not stick.. My bad...
  20. Ok.. A couple of things to consider?? What are you welding? 6mm plate can be welded with a 130amp welder.. 180 is pushing 10mm plate.. Next is your power situation.. Do you have a good 15amp supply?? If not your restricted to a 130-140 amp welder.. Stick to a brand name though.. BOC do a nice little compact stick welder. 130a and smooth...
  21. Yea they are top spots.. Fishing, 4x4'n and out of the big smoke...
  22. Well I got told this by a good 4x4'n friend with 2 patrols so I gave it a crack. I got an extra 20ltrs but it's up to you on how well you do the job And tank size.. What I'm about to explain is very simple. All your doing is removing the air gap in your tank. Manufacturers usually give 30% expansion gap. So the steps.. Step one, locate some way to get into your tank... In my 91 LWB GQ it's a simple matter of lifting the floor matting, remove the cover plate and carefully take out the sender unit.. Others may have to remove your tank.. This took a bit because my plug was a bit seized and they ain't very forgiving with length... But all the hoses and bolts came out very easy.. Next to find the breather line.. Mine was towards the rear . It should run next to the filler neck.. Now as you can't fit your head I the hole the whole lot is done by feel.. Once you find the line you can get to work.. Grab a 16mm ring spanner.. Slip the ring over the line (it's metal by the way) and straighten out the bend in the last 100mm of the pipe.. Once happy with that, feel along the pipe for a bracket.. Once found simple push or pull the pipe to flatten the bracket and push the pipe towards the roof.. I got mine within 2 mm of the roof.. The closer you can get it the more you will fit... Clean all your seals and bolt it all back together.. Warning... I have been advised not to fill and leave the car.. As you are removing the air gap you should only fill to the top and then drive... Spillage may occur... Happy modding..
  23. Quite simple in the 91 LWB models. Utensil you have to drop the tank.. I'll do a how to thread.
  24. Thanks for the offer but got some friends down that weekend.. In mount gambier now. Family farm is on the yorke peninsula.
