dav
    9
Everything posted by dav
  1. I have had many issues with the sister in-law about posting pic's of my daughters and checking in at our house. but she doesn't see the any issues with it as all of her friends are decent people all 750 of them. But when it's time to move house it's the mother and father in-law 70years old helping. It's funny how people can let 750 people into there house and families lives.
  2. I leave mine on a projector charger all the time as the patrol is not my daily drive. Had the batteries checked the other day both still punching out the same CCA as the day I installed them 4years ago.
  3. Yes you can and I did but you need to switch it on and off. Also put a bypass in pas the pump with a valve so if the pump stops you can still pull water threw the hand pump. Thats what the two valves are for in the photo. As you can see my pump is in the side hatch of the trailer. Here is a pic of the under side.
  4. I used a 4.3LPM pump but a 3.8LPM would do the job. I got mine from Opposite Lock this one http://www.enmachind.com.au/poly-rv-accessories/tank-fittings-accessories You don't need a big pump to use a lot of water in the bush and you are not running a fire hose. I all so have son/off switch on mine but it turns off automaticly when the tap is turned off.
  5. Some more of the Kitchen.
  6. My Southern Cross camper trailer (Bush Mate) .It was a ex demo and got it last july. It came with the following 9ft Tent Kids room Safari roof Full annex with walls Slide out stainless steel kitchen 80L water tank Large tool box 2 x Jerry can holders 9kg Gas bottle and plumbed to rear of trailer with quick release coupling Treg coupling LED brake and clearance lights 12V system with 110 amp battery Electric brakes Hand brake
  7. Mine AGM is in a fully sealed tool box. Nice camper trailer.
  8. Had it fixed on mine already. Seen it wagons with 40.000km on them. Thanks for the heads up Pete anyway
  9. Penrite 10w50 semi syc
  10. Pedders sell rubber caster correction buster which flex more than neoprene .
  11. You don't here that very often. Good service from a dealer. I have two Mazda dealers close to me one charges $135.00 p/h while the other is $85.00 and does a better job. So if you have a good dealer you are lucky.
  12. dav
    hmmmm?
    I like this format. thanks for starting this new site. So start posting.
